Фото с размерами мини багги
Добавлено: Чт ноя 01, 2007 12:39 pm
рычаг передней подвески
Double A-arm setup
7/8 inch .095 steel tube
3/4 bolt
5" for short, 11" for long part
The best way to make A-arms is to use wood jig. This will ensure that they come out same. A very very important.
This is what I have been told, something to think about:
"when you use dual A-arms, there's a problem to overcome: when the suspension travels up, the wheels push outwards as the A-arms get closer to horizontal. what you can do to fix this is make the upper A-arm shorter than the lower A-arm. this way, when the suspension travels up, the top A-arm, being shorter, pushes outward at a greater rate, making the top of the tire lean outward. when the tire
leans out, the part of the tire contacting the ground does not move outward." -Eric (erk7000)
Spindle is 4 1/2in.L x 3/4in. dia.
And this what should it look like when everything is put together.
Добавлено спустя 3 минуты 33 секунды:
Добавлено спустя 1 минуту 54 секунды:
рулевое управление
Steering system
I used old steering rack from Hyundia Excell rack ($25)
Double A-arm setup
3/4 bolt
рулевое управление
Steering system
